Driveshaft pulled out of tranny with flip kit install
84 Shorty
Grovetown, GA
Andrew
As the title says, the drive shaft pulled out of the tailhousing and tranny fluid went everywhere. What would cause this? Axle sitting on the leaf springs too far back? It does look good though.
84 Shorty
Grovetown, GA
Andrew
I’m done working on it today, but to test that theory I’m going to jack it back up again and see it raising it makes the yoke slide back In
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Nice looking short bed!
84 Shorty
Grovetown, GA
Andrew
Is that normal, I did some digging online and it was saying the yoke should be withdrawn about an inch. It shouldn’t be butted up against the tranny. So is the picture of my yoke ok then?
Craig 85
Nashville, TN
454/TH-400/NP205
I have heard of this. Lowering a truck is just the opposite issue I have with raising my trucks. The lower you go, the further the yoke will pull out. On my K30 it has a slip yoke out of the transfer case. The transmission shop said there should be a total of an 1 1/2" of movement on my yoke.
You don't want the yoke up against the transmission when it is sitting static because in your case, if the suspension droops, the drive shaft will force itself into the transmission causing damage.
rpcraft
Robert
LS 6.0 364 CID
What you really need to do is check some of the websites for custom driveshafts and use their instructions for measuring for a new driveshaft and use that info to compare to your current one and then see how far off your lengths are. Looking at a picture of how far your short your shaft is (no pun intended) is not going to really help you in this case because it can't account for the amount of suspension travel you may have. Did you change anything with your transmission or just do lowering springs?
84 Shorty
Grovetown, GA
Andrew
I took it out today for a drive, transmission shifts better now with a little play in the yoke. Before it was butted it and it would throw hard in reverse, now there is no issues. No leaks, drives good so I’m going to leave it.
jodygraham64
