Best Cleaning Option
MtBraun
South Dakota
Disassembling a 14 bolt SF and there is a lot of residue and some flaky rust in the axle tubes and center section. What's the best way to clean this out? I was thinking a hot tank but not sure if there are any near me large enough for a complete differential assembly.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Long wire Brussels bore brush, cut handle off and attach to a drill, could hot tank it, I would likely just wash it out and spray some penetrant - it’s sealed in the axle tube, long as it’s clean when you reseal it’s moot
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
There should be some kind of drill attachment for bigger pipes, for like plumbing. Probably like a 2.5 or 2 3/4 wire brush. With a long "handle"
85Shortsquare
