are we there yet project
yevgenievich
Viktor
sad
very sad
less sad
So you're working on it again? Awesome!
Have couple of weeks to make progress before school starts. Even work I thought was done, is not and have to go over.
yevgenievich
Viktor
sad
very sad
less sad
Step backwards.Was looking to be driving soon, but a lot more work needed.
RoryH19
Rory
R10 Silverado SWB
I just noticed this thread started in 2016. I applaud the dedication. My k5 was almost 3 yrs (6 months at paint and body) and I was ready to push it off a cliff.
yevgenievich
Viktor
sad
very sad
less sad
Was rushed, but mostly covered with primer. And more cutting.
yevgenievich
Viktor
sad
very sad
less sad
I really need to redo a lot of the work the body shop did. I coated it for now, but their welding is worse than my harbor freight welder.
78C10BigTen
pennsylvannia
C10 BIG TEN
Holy hell. Stevie wonder coulda done better! Ive never welded and i coulda done better...
yevgenievich
Viktor
sad
very sad
less sad
There are two braces missing on both sides of the quarter panel as well. Test fitted the parcel shelf thing and still trying to decide if I need it in place before cutting the tubs out. Much easier access to the inner tubs with the parcel shelf not installed.
yevgenievich
Viktor
sad
very sad
less sad
It keeps getting more expensive by the minute. Upper dash is out as well. Also ordered everything to replace the work body shop did.
yevgenievich
Viktor
sad
very sad
less sad
Took a bunch of measurements and keep cutting things off. Non of the inner bracing was actually welded to the panel, and a bunch of other holes besides the burned/failed welds.
yevgenievich
Viktor
sad
very sad
less sad
Few more weeks and not sure if there will be anything left at this rate. Sold the front subframe today and put the engine in the corner of the garage. Subframe connectors actually made for good handles to wheel the thing around until the motor was out.
yevgenievich
Viktor
sad
very sad
less sad
Some more of the parts coming in.
That's some dang impressive hardware. Very nice!
yevgenievich
Viktor
sad
very sad
less sad
Couple of more things trickling in.
yevgenievich
Viktor
sad
very sad
less sad
Still waiting on half of the sheet metal.
yevgenievich
Viktor
sad
very sad
less sad
Tried to paint inside of the subframe rails along with some other metal that needs to be installed with some epoxy primer.
loki1978
