Man that sounds likealot of things to juggle that's for sure Lol how ever it sounds pretty fool prof though I can't wait to start my S.A.S in this Tahoe life will be so much easier without the torque bars in the way plus I'll be installing dual exhaust as well I've also been looking for the direct port fuel injection manifold as well and a 4L80E with a Tcase
Not much at all juggle is my point. Just in detail, it's a lengthy post. All I need is 2 flywheel/flexplates, (1 for autos, 1 for manuals) 2 starters (1 for autos, 1 for manuals), 2 transfers cases with adapters (1 for autos, 1 for manuals), and an Auto Ratchet shifter. That's it. The manuals have their own shifter. Then any one of those 4 transmissions will bolt right in with no mods, cutting or welding. Uses the same trans mounts, crossmembers, driveshafts front and rear and no exhaust mods to get around linkage or over crossmembers since it stays in the same place for all 4 applications the way I'll have it set up.
That's just the way I roll. I like to have options. Also in my 62 and 64 GMC, I had every motor configuration you could imagine too. Big GMC V6, I6, V6, Small Block and Big Block, all without cutting or welding. Just moved motor pads on the frame. and the gas pedal linkage rod, had one for the I6 and one for everything else. And I did have a set of exhaust pipes for each, on the I6, Small and Big Block. The GMC V6 is what I took out of the 64.
