89 Suburban Dashboard & A/C Ducting Removal
CaliDude76
NorCal
Sal
Nineteen Eighty Four
C-Ten (Custom Deluxe)
Three Fifty
I am killing the ac aspect of the truck and using the empty vents for other accesories, like a tach, storage, cup holder, etc.
Sunday I am hitting Home Depot to find that self adhesive ducting foil HRPC mentioned to seal that lousy defrost duct joint and also some 1/2 " PEC for the door strikers.
Ahhh...I see, wow it must not get that hot over in your neck of the woods in the summer..
I would melt if I had no A/C in my square... we fry in the summers here... shoot it's late October and we're still hovering around 80
There is an OEM pocket that goes in that duct hole for non AC trucks. Just find a non AC truck in the junkyard and rob a pocket. Actually, hit up Oneluckypops, he is adding OEM AC to his non AC truck. Damn, that reminds me, I shoulda worked on that **** today. Dammit !!! I was to busy anyway. I need to get that **** to him.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Does that OEM pocket screw in from behind or is it molded in?
I also thought there was an OEM pocket on the lower left below the headlight switch?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Mine is moulded into the instrument cluster cover itself.
Joeairforce
Maryville, TN
Joseph
V2500
6.2L N/A Diesel
No comments on why the defrost duct is so out of match with the heater box????
:think:
Don't know... But mine is/was the same way as well as the '91 burb @ pick-n-pull that i was swiping parts from....
I picked up a roll of foil backed, foam tape, about 2" wide, from Home Depot. Next time I pull the dash apart I am going to seal that joint.
Joeairforce
Maryville, TN
Joseph
V2500
6.2L N/A Diesel
Mine's apart now so I may go get some of that stuff and do that now when I go to put it back together...
Yeah, it should work good I hope.
We just went through the wiring not long ago in another thread, buddy...
http://www.gmsquarebody.com/forum/showthread.php?t=1924&highlight=tach
Factory or aftermarket?
Either one is going to pretty much be the same. Most aftermarket tachs have 4 wires, white, black, green and red.
Red: 12+
Black: ground
Green: distributor - most caps are marked "TACH" and that's where you plug it in.
White: illumination - to the dash lights.
As Quoted !!!
Chype1
