Catbox
- Jul 12, 2018
- Just Outside of Portland Oregon
- Peter
- C20 Silverado Camper Special
Here we go again with the rear end spitting its guts out.
This will be the 3rd failure with the first two being extreme budget rebuilds and the last a full boogie Eaton Detroit True Track.
On Friday night I was in a parking lot turning to get into a lane for a space.
As I was turning, I felt the drivers side bind up and pop a couple of times.
Then nothing.
Seeing as I have done this boogie before, I stopped and checked stuff over.
Nothing looked out of the normal.
All joints are tight and no leaks present under the back end, which is pretty spiffy for a 225,000 mile daily driver.
So yesterday @Maxwellvis and I pulled the diff cover to see what we could see.
After the oil oozed out of it all the teeth on the ring and pinion looked ok to me.
So I stuck my finger in there and felt around.
I found many small pieces of metal, not slivers, chunks.
I have called the new rear end guy that was recommended to me and we will be going with a Yukon Dura Grip this time.
We will be pulling the whole rear end out of the Sub to verify it is totally straight and good to use.
I don't want to be doing this again any time soon....
Then nothing.
