Wiring nightmare!
Nick Prater
Oswego il
Nick
So I recently purchased a 1979 chevy k10. It has a 90s gmc automatic steering column in it but truck is manual. Here are some of my issues. The turn signals don’t work. The right signal on dash turns on when i push the brakes. Doesn’t blink, just illuminates. When I hit the brakes the marker lights come on as well. The truck has a mid 80s front clip. The dash lights will only come on if the switch is in just the right spot. Can anyone please help me figure this out? Even if I can just get a new harness somewhere?
1985c20
Torrington, CT
Chuck
You've got a host of problems. I would start with checking/cleaning all grounds and bulb sockets. I know any time I've had the turn signal indicator lights light up in the dash on cars I've owned its always been a bad ground.
yevgenievich
Place
Name
Year
Model
Size
Behind left side of cluster, near top of parking brake, battery to core support, engine to firewall, frame to engine
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Make sure all the bulbs are the correct ones. If someone shoved a single filament bulb where a dual filament should be it can cause the turn signal indicator to light with the park lamps on. Push and pull the hazard switch a couple times, sometimes that can correct funky turn signal issues. Get a wiring diagram for both the 79 and whatever year the front clip is. Make sure the bulkhead connector pinout location is the same. Good luck, I hate trying to fix other people’s “repairs”
Square Builder
