Wire Identification
Shalpass
Runaway Bay
This wire was was all taped up with a vacuum hose that goes thru the firewall...plug wasn't plugged in and neither was hose...what is it and is it needed?
Shalpass
Runaway Bay
What is this?. Has a vacuum hose attached located on firewall
Shalpass
Runaway Bay
What is this located by the distributor
Shalpass
Runaway Bay
What plug is this on the firewall that isn't puffed in
Shalpass
Runaway Bay
Any ideas as to what these plugs are
Shalpass
Runaway Bay
What is this
Shalpass
Runaway Bay
What is this?
Shalpass
Runaway Bay
What is this
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
That's the vacuum advance canister for your distributor
SlickGTP
Houston, TX
What is this
The vacuum port off the back of the carb/throttle body is for the Vacuum Booster for the brakes.
What is this?
Hard to see what your pointing to, but if it's a thingamagig coming off the intake manifold behind the carb/throttle body, then it's a vacuum manifold for various things that need a manifold vacuum reference. One thing typically plugged into it is a modulator on the transmission.
Hard to tell what the other unidentified items are without being able to see what's around them.
Shalpass
Runaway Bay
So do I really need all the vacuum hoses for my truck to run ok
MadOgre
NA
NA
NA
NA
NA
TCC lockup switch. Route the hose to manifold vacuum. It tells the torque converter when to lock up or disengage. Its basically a manifold vacuum operated switch
tman894
