windshield wiper wiring
streetrod don
arkansas
Donald
blazer
6.2 LT4
I am building an 86 Blazer. Scotts suspension, LT4. I am using an Ididit column which does not have a wiper switch. When I removed all of the old wiring i saved the connectors for the wiper motor. I have an American Auto Wire 2 speed switch and will not be using a washer. I need a diagram for the 5 wires on the wiper motor. thanks Don
streetrod don
arkansas
Donald
blazer
6.2 LT4
That would be an excellent diagnostic diagram but I need a diagram showing the wire runs from a switch to the wiper motor.
Doppleganger
OH-MI: Just like it sounds
I know that the harness from the wiper motor runs to the main gang connector. If THAT harness is bad, I will see what I have duplicates of as I collected them (and new connectors) to remake a new harness from the motor to the connector. That was one sub harness I never saw anyone make.
Snoots
Roger
Jimmy Sierra
350 w/203
Correct me if I'm wrong but if you had pulse wipers there was a separate harness that ran thru the firewall to the motor.
Shak379
