Will this tranny work in my truck?
Scratcher
San Antonio
Erik
My '79 Chevy has a 350 from an '81 vette with a th350. I do a lot of highway driving (my girlfriend lives an hour way). So I am wanting a th700r4. I have the opportunity to pick up a working tranny out of a 90's suburban. Problem is the suburban is a 4x4. What will I need to make this tranny work in my truck?
yevgenievich
Place
Name
Year
Model
Size
Not worth it usually. Has to be taken apart to change output shaft
Preston
Mechanicsville VA
Preston
The tail shaft will have to be changed out, I have the opposite problem I have 2 700r’s for a 2x4 and I need one for a 4x4. You will have to pull the transmission apart and swap them out
Welcome to the GMSB site :boti:
eskimomann209
Modesto
Marcus
Haha
Or
Bolt a t case to it and adjust mount as needed.
oh and drive line and leave in 2wd forever with no front output shaft
Or trade with Preston
Scratcher
San Antonio
Erik
Thank you for your input. I’ll keep looking for a 2x4.
MrMarty51
Eastern Montana
Martin
Install the burbs 4X4 components under Your two weeel drive, problem solved.
Welcome to the forum.
You'll prefer to find one from an 87 or later for the best reliability. To bad that 90 unit won't work. I wish I was closer to that guy. If it was cheap enough, I'd buy it for my K5. It still has the Original 86 unit it. I'm not sure if it still works or not until I get a running engine in it. I do have a 89 core to build though if I need to.
Dons79C10
