Wich wire”s” do I disconnect when checking compression
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
My truck still won’t run after trying turning the cap all sorts of ways. What wire do I need to disconnect to check for compression?
Question 2 is that silver nut I’m pointing to called an oil pressure switch?
Hugomartin
Banned
Nc
Hugo
Closeup
Hugomartin
Banned
Nc
Hugo
Wich one is the fuel pump relay I only have one tank what is the other relay for?
350 w/203
1. You can just take the cap off.
2. That's what it appears to be.
3. Don't know about the relays.
JIMYB
