- Sep 3, 2024
- Nebraska
- Goober
- C15
@PhotonFanatic
So, after bypassing the back and forth, you say you're letting the body shop do the body work? If so, then are they squirting the epoxy primer on it, highly recommend that you do this. Epoxy is EXTREMELY TOXIC and letting the pros lay that stuff on is highly recommended before you take it home. You'll be glad they did and it will last as long as you want it. Epoxy is one thing I won't paint in a home garage-maybe outdoors with a quality mask but still if able, let the pros handle epoxy. A good friend of my uncle had a massive coronary issue from spraying epoxy and not using proper ventilation, attire or mask. Good thing though about epoxy is that "filler" can still be applied on top of epoxy primer if needed just as if it was bare metal then rattle can regular primer on the repair. And old rule of thumb when laying paint down is thick over thin.
