Where to go from here...
8T6K5
AZ
L98 350 TPI
Anybody who's been around here for the past year should know how much time0work I have put into my K5.
Today as I was going to change the EGR valve I found this:
Not what I wanted to see, not right now at least.
MrMarty51
Eastern Montana
Martin
Oil and water ?
Try cleaning it out and see if it reoccurs`s whut I`d do.
Unless You been having pwoblems.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
How did it get there in the first place?...pcv not in the intake hose. pick up something through the filter? Filter oil maybe?
8T6K5
AZ
L98 350 TPI
Pass side PCV vents into the TB....pulled the hose and looked in it....thats where it came from.
So is that what the oil in the motor looks like too?
8T6K5
AZ
L98 350 TPI
Jims86
Patterson,Ca
5.7 TBI
philjafo
everywhere
phil
k20 scottsdale
350/sm465/np205/d44/corp14
Couple of short trips = condensation in the valve cover area. How's the coolant level? Sometimes aluminum intake and iron heads causes corrosion and a leak at the coolant passages. Maybe do a compression test. I hope its not too bad, I'm jealous of your k5, gm's tpi is one of my top 5 favorite engines and same for k5s. Good luck buddy.
Jims86
Patterson,Ca
5.7 TBI
Could there be a crack in the throttle body coolant manifold...in the throttle body side?
Hoping for something minor.
If not, just get discgusted with it and I'll take it for ya. !!! Jus Sayin...
8T6K5
AZ
L98 350 TPI
Couple of short trips = condensation in the valve cover area..
Describes most of my driving with it. As a last ditch effort I'll be installing an air-oil separator on the pass side.....maybe even driver side too.......?
Sent from my iPad using Tapatalk
Hard
