Where Does This Connector Go
surfrocker3
Palmdale
c30
My 1987 Silverado Crew Cab Dually 3500 has this pictured connector dangling down behind the dash. I can't find a connector to attach it to. Tried checking wiring diagrams, but can't seem to find it. Anyone out there know where it belongs? Thank you.
Finkaire
Finkaire
California
Loren
Silverado c10
Doesn’t appear factory, colors could be from the neutral switch? Maybe a for a kill switch? I would start by testing, start with ignition on, off.…See if it’s connected to the fuse box?
dertsy
nice
nicak
c35
Gasoline 1.5L, Four Cylinders in line
Good info! Front panel connectors are nice and easy on a test bench, but I hate putting them on when I've got the board in the case already, but not really an option!
192.168.100.1 192.168.1.1
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
that looks like the brake switch connector for the torque converter clutch. If the truck has a TH400, that would explain why it was t plug into anything.
FenderBanger
