Where can I find a fuel tank wiring harness??
rscustomrods
Rich
So my truck will start and run and then will die. I have determined that the fuel selector valve is losing power, thus not allowing fuel from the drivers side tank to continue to flow. I have traced all the wires back to the rubber plug that passes through the firewall. I have power from the fuel switch to the firewall, but it is intermittent past the firewall to the fuel tank selector valve. I either need a new plug that I can splice the wires into, or a whole new harness for the fuel system.
Does anyone know if these plugs or harnesses can still be purchased and if so, where? I cannot find one anywhere.
Thanks for your time,
Rich
SlickGTP
Houston, TX
Best place I can think of is a junk yard, but it's just one wire. I ran a new one for mine and spliced it to the old wire near the switch.
rscustomrods
Rich
I gave up and cut the rubber plug and put spade connectors on the ends and plug them in individually to each spade coming out of the firewall. I then put some wire loom around the wires and it fit perfectly in the hole and stayed somewhat waterproof. I shouldnt have too much water on that point of the firewall anyways. Long story short, it works:)
:waytogo: And that's how it's done !!!
