What's the first move?
cobbisbobobbis
California
GMC C25
Play with all the switches and knobs see if there's anything that doesn't work ie. wipers, washer, heater settings, if it has the auxiliary tank flip the switch back and forth see if you can hear the solenoid click. Will give you an idea of any items that may need repaired right away rather than buying it and find out the first time it rains the wipers don't work or there's an issue with the blower motor or like in my case a full tank of gas you can't switch too.
Yeah absolutely, I know the passenger side tank is disconnected probably because the valve broke or whatever. I've heard that's a common issue with these trucks.
Driveline and frame (flex at the steering box) is all I would be worried about with your description. If the cab is fine except the corners and the bed floor is fine you should be fine.....again if like you said it's a steal. Fenders, doors, rocker panels, and complete bedsides can be had.....complete bedsides being the most expensive.
Of course you can weld in patch panels on the above mentioned items.
Yeah absolutely I am going to check those things. As it looks right now everything is solid, I believe.
Welcome from Austria. If it runs, drives, stopps and has no cracked frame go for it.
Absolutely!
If you can daily drive a 1973 C25 with minimal investment after the purchase, that is a pretty rare find.
Yeah I do say so as well.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
You’ve got some really good stuff in her 454 a 400 transmission. It’ll have the big 14 full floater with a 13 inch brakes in the back. It’s got the heavy duty suspension those campers specials had all the good stuff on them. I’d buy that in the New York mini.
86 C10 Shortbed
Ohio
Mark
5.3L
Welcome from Central Ohio
cobbisbobobbis
California
GMC C25
Yes, I was looking at all of the specs and such before I went and got it. I went and looked at it and it had one spot of rot on the dog leg. I bought and drove it home (from the next town over) it ran great and rode fine. It just is running a little bit hot, not overheating just a little bit hot. I'll have to look at other threads on here or make my own.
jw23655
