what type of d60f locker do I have?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
opened up both diffs to check fluid state. besides being an idiot and wiping stuff with a paper towel and getting lint everywhere, i'm pleased to find that everything must have been serviced not long before I bought it. everything looks fairly new internally. I've put less than 10k on it in the 6 years I've owned it. @Jrgunn5150 already confirmed that my 14ff locker is a Detroit in my build thread. I'm now looking to identify the D60f:
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
here's the rear axle:
CSFJ
What does the other side of the front carrier look like? The sides that are either on the top or bottom in the pics. Right now, it kinda looks like an open carrier. It wasn't unheard of for the m1008 trucks to get a front locker, but most were open diff. The m1028 or m1031 were standard with the front lockers.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
what type of setup in the d60f? detroit or what? what brand of fluid/viscosity do you guys like to run? what type of gasket and/or sealant do you like to run? looking for responses from people who've done more than one or two...
thanks!
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I'll open it up when I get a chance to get some better angles. it will spin all four at the same time in gravel while hooked to a concrete truck. not sure if that is a telling sign or not...
edit: maybe an lsd?
CSFJ
yeah, that isn't really a guarantee, technically, if they have an equal lack of traction, they should both spin. Don't get me wrong, that would be seriously badass, if you ended up with one of the few m1008s to leave the service with a front locker, but I wouldn't hold my breath.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I think I found the angles you were looking for in my photos:
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
if it's open, what is the best locker for snow road performance...not rock crawling and something that won't double my turning radius?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
..and I can't find any pictures of what the trac loc diffs looked like in the d60f.
CSFJ
I hate to say it, but that rear diff looks like a Gov-loc rear, not the detroit locker that should be in there.
This is the pic of a 14 bolt I sold last summer, that had the gov-loc, which is a limited slip type diff instead of a true locker.
CSFJ
There really isn't any front locker that is good for street use. The front hubs would need to be unlocked(or at least one of them) to allow the fornt tires to turn at different speeds going through a corner.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
do you have a picture of the Detroit that came in your 14ff?
is it normal for my front end to push when in 4 low, effectively doubling my turning radius?
CSFJ
give me a bit, I can go out and pop the cover.
yes, four low will push the front around.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Yes, if you have a locker.
The rear goes inside a open carrier, so it's tricky to see.
For the front, I would run a Detroit there as well, and just unlock a hub if I want to run sharp offroad. Getting into ARB's or OX's doubles the cost, and any type of "posi" is just going to unload as soon as you lift a front tire.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
All depends how it’s set up.
jgrind88
