Voltage to the fuel pump?
Nightrider24 7
Ontario
Jamie
Mine reads 8 volts. I think it should be 12 at the tank? My pump works but is weak. Electric fuel pump. Pressure is 5lbs. Could this be from low voltage? What do I replace? Thanks.
yevgenievich
Viktor
sad
very sad
less sad
Check the gnd
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Seems to always be the ground in the drivers frame rail, every single time it seems, from either corrosion, bolt not getting torqued down, or a bad ground wire.
Always seems to be ground wire related in my experience lol
flynhigh88
