Vent Window Question
Ken B
indiana
ken
Question, I have removed my vent windows and one of the windows has a damaged piece that I was wondering if it can be removed and replaced? It is on the inside of the division bar, it has a stainless piece on it for the vent window catch. It is black metal and it was dented/damaged. Can this be removed or replaced? The window is in tact and usable just wondering if that "interior trim" piece is removable
ali_c20
Austria
Alexander
C20, K5
Ken B
indiana
ken
sorry dont have a pic at the moment, on your post where the lmc logo is on part #1, where the latch rests. It is a thin metal strip with the stainless latch catch. that thin strip of metal is what I am inqiring about. I do not see it listed in the parts. maybe thats the answer to my question?
Doppleganger
OH-MI: Just like it sounds
About a 2" long stainless piece? If so, those come off - I removed mine when I had the frame powder coated. Probably have to bag one used in a yard.
Ken B
indiana
ken
heading out to the garage for a pic. i
Ken B
indiana
ken
its about 18 inches long and 1.5 inches wide......the stainless piece is on this....
Ken B
indiana
ken
I am talking about the black strip that the stainless is on, is this a replaceable/purchasable part?
MikeGs1982
McKinney
Hey, saw your post....kinda related, but not completely. They make a trim paint that you can pick up at automotive paint shops that comes in a rattle can that makes that black part look really good. Mine had a little surface rust on them when I took the doors apart to paint the truck. I lightly sand blasted those and hit them with that low gloss, almost matte trim paint and they look great. It's held up really well, also. Good luck on finding what you need.
M
Ken B
indiana
ken
thanks for the replies and answers......on to the net question. I have watched a video that says there is supposed to be a bolt in the door under the window. I would guess as a pinch point to pull the inside and outside of the door together under the vent window. My doors do not have that bolt. I have checked 4 doors that I have none have that bolt. these doors certainly arent original and unmolested. What's the rule of thumb on this bolt??
Terry Wilkerson
Kansas
Terry
GMC 1500
There should be a round rod bent so that it jogs around the vent window chanel that extendeds down inside of your door. You can see the bolt on the door. The outside bolt is under the mirror cover. This rod does tie the inside and outside of the door together. I heard some sat it is not necessary if it is missing.
Ken B
indiana
ken
Thanks I have that rod . I am referring directly below the vent window.. I will get a pic shortly....
Ken B
indiana
ken
Is there supposed to be a bolt in the circular hole at the top of the door?
Terry Wilkerson
Kansas
Terry
GMC 1500
Yes there is a screw in that hole. I took it out for a measurement. I think it is in the lower wing window frame.
Ken B
indiana
ken
huh,,, 4 doors and non have it.....if it werent for bad luck.......
wilson79
