Valve cover bolts
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
In my pursuit to figure out my annoying an persistent oil leak, I changed out my valve cover gaskets. Noticed that my valve covers where bent where the bolts go and got some new valve covers.
I installed them and tightened them down. Today I now have a leak that is bigger than before. Perhaps I either tightened them too tight, or not enough? I'm really upset. From what I have learned, the torque spec is 5ft/lbs. I have a torque wrench but it doesn't go that low.
What is the best way to torque down the bolts without a torque wrench? Are load spreaders a must?
Please help.
Thanks in advance.
Brandon
CSFJ
Load spreaders always help. Torque wrenches are available in small inch lb increments, but I always tightened the valve covers by hand. 5lbs isn't much, use a 1/4 drive ratchet, and a long extension and you should be fine.
Georgeb
Wisconsin
George
K10 Burb Z71
Make sure you are using good quality gaskets. The reusable silicone ones are really nice. If your valve covers are flt it should only take tightening the bolts with a nut driver.
firebane
Calgary, AB
Curtis
If you have perimeter bolt valve covers get yourself some felpro blue gaskets. Then get some spread bars and t-handle bolts.
After you've done that if your valve covers are warped fix them. Find a flat edge and clean up the edges. Then use acetone and clean up the surfaces on the head and valve covers.
Re-install with no leaks.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Should the blue fel-pro gaskets go on dry? Are they reusable?
firebane
Calgary, AB
Curtis
Yes and yes. Its what I put on my truck and haven't a single problem. The bolt holes have little metal circles so you can't over tighten them either.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Gotcha, thank you.
Not sure if I can use the T-handle bolts because it would hit my AC compressor.
Would you use them on all 8 holes?
firebane
Calgary, AB
Curtis
Gotcha, thank you.
Use what you can and if you can't fit the t-handles then just use a normal bolt with the spread and just hand tighten.
