WFarm
- Jan 11, 2023
- Central Virginia
- Paul
- K5 Blazer
The 454 has been running OK, but not quite right. Even with my crappy hearing I could hear pinging when accelerating.
Today I went back to check timing, thinking maybe I had too much advance. Disconnected the vacuum line from the manifold port on the Edelbrock carb, plugged it and set initial timing to 8 degrees BTDC. When I reconnected the vacuum advance hose I heard no change in the engine so checked this with the timing light. No change.
Checked manifold vacuum at the carb. Readings were 17-19 inches vacuum. Pulled a vacuum on the vacuum advance and it held rock steady. At this point I was a bit confused so pulled the hose from the distributor to the carb and tried to blow through it.
The hose was completely blocked with a small ball! Looked like a snake had eaten a cat. Have no idea where this ball had come from but I believe it’s been bedeviling me for a while now! The ball is too big to have come from either the carb or vacuum advance canister; there is no way it could pass through the connections of either one.
Apparently when I reinstalled the intake manifold recently and replaced the vacuum hose with one I had in the shop i didn’t notice it was plugged. My bad………..
