454 timing heat soak and vapor loack
Smoky1978
Minnesota
Steven
Sierra
454 timing
I have a 454 from an rv, stock except headers.
I had the timing setup at a shop. As I have been learning I checked the timing and it was set at 20 degrees. Vacuum advanced disconnected and engine warm. I have been reading timing should be anywhere from 4 for smog era vehicles to 14 for stock rebuilds.
let me try to rewrite this so to give a little more details on symptoms
new champion radiator and electric fans
new fuel tank and sending unit and fuel pump. New rubber lines. Steel lines look good and blew air through the lines no plugs or leaks. This is how I found out the top of my sending unit was rusted out.
will idle forever and start back up without issue engine stays at 195 or so.
I can drive for about 30 mins temps climb to about 210 but then when I come to a stop it will start dying on me. I have spark but no fuel. No fuel coming out of the carb jets and extremely hard start from start.
Don't know exactly how long to wait but come back out to the truck 8hrs later and it started right up without issue.
nvrenuf
Mobile, Al.
Electric pump in the tank?
If so, I’d rent a fuel pressure gauge kit and have all the tools ready to tap in to the line to check for pressure. There should be a filter on the passenger side frame rail, you could tap in at the fittings on one side of that and check for pressure while it’s acting up.
Is your exhaust routed close to the fuel line?
Do you still have a return line?
Smoky1978
Minnesota
Steven
Sierra
Mechanical fuel pump. Return line works.
Fuel lines are in the stock location I. The frame rail. I haven’t tried making a heat shield for them.
Just from what I read 20 degrees base timing is a bit much and heard big blocks running warm due to far advanced timing. The motor does seem overly warm.
Want to verify my starting point is correct with timing at least.
They also run hot from too little timing and that's actually more common and more heat. They usually ping before timing gets far enough advance to cause overheating. Big block chevy typically wants 34° BTDC total. That is disconnect the vacuum advance,rev the engine until the timing quits advancing,time it to 34° at the rpm it quits advancing,let timing at idle fall where it falls reconnect vacuum advance to manifold vacuum. Now it is entirely possible that the timing was advanced to cover up another problem, a vaccum leak,plugged carburetor jets etc. Also I am not conv8nced your fans and radiator are right,lots of overheating problems have been cured be going back to the factory mechanical fan,which moved many times more air than electric fans. Another fun fact about electric fans and most shrouds after about 20 mph,they become obstacles to air flow.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
20 degrees on a stock big block is bananas lol.
I'd usually start at 10.
I'd usually want 32-34 ish total, all in by 2500.
But, there's a lot of variability and they kind of want what they want.
Smoky1978
Minnesota
Steven
Sierra
Thank you both for the replies. I agree with you on the fan. Shop I brought too said I needed replacing so think I got hosed unfortunately.
I don’t have a tach so is it best to set the initial or total timing? I don’t have a tach so makes it kind of difficult
You don't need a tach just rev the engine until the timing stops advancing set your total there
Total is way more important than base. If you don't have A dial back light,you will need to mark your balancer. If it doesn't run right after setting total,lmk. We can teach you how to verify timing marks are accurate.
Look for a restriction of some sort between the pump and the tank even the tank sock. Liquid under pressure raises tge boiling point,that's why we pressurize cooling systems,liquid under vacuum lowers boiling temperature,that's why we put A/C under vacuum,to boil out the liquid. So the more vacuum you have between the inlet side of the pump and the fuel itself increases the chance of boiling and vapor lock. An electric pump back by the tank as a pusher pump to your mechanical pump would keep the supply line 90% under pressure and most likely eliminate vapor lock. Using a low pressure pusher allows you to keep all your stock plumbing at the pump and to the carb.I personally am running an airtex e8016s blowing through a factory pump.
Smoky1978
Minnesota
Steven
Sierra
So I like to read these articles completed so I am going to continue what’s going on.
So went out bought a timing light marked distributor. Removed and plug vacuum line.Rechecked initial 20 so I moved down it down to about 10.
Revved it up a couple times to visual see what was happening when I moved the distributor.
I got it set at 34 total timing. Checked initial it’s about at 12. That is more of what i was reading and you guys were saying.
Waiting for the wife to be home to take it for a drive so I can get picked up if need so will you guys posted
What do you mean " you marked the d8stributor"?
Smoky1978
Minnesota
Steven
Sierra
finally got back to this. turning down the timing seemed have solved the problem. Thanks again everyone for you help
doo-daa
