Under hood light
calredneck
Cailf.
Kerch
I have a 89 K5 blazer the under hood light not working I don't see a switch on the hood for a mercury switch wondering how it works
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I would imagine it's in the lamp assembly, since you have to grab the lamp to bend it to turn it on and off.
Snoots
Roger
Jimmy Sierra
350 w/203
switch is on the front of the lamp assembly that holds the reel in my 1990 suburban
Different assembly.
If the light is mounted to the center rear of the hood, it has a mercury switch built-in.
gmbellew
Kansas city
glen
suburban 1500
Different assembly.
ok. figured his being an 89 and mine a 90, that they'd be the same. but pics always help! mine is mounted on the firewall towards the passenger side of center.
calredneck
Cailf.
Kerch
Ok thanks all for the responses
I was going to put on a pic but spaced it out I guess this light you grab it has a cord and when you pull it off the fire wall it comes on and you put it back it goes off Thanks again
gmbellew
Kansas city
glen
suburban 1500
switch is the lower passenger side corner. the little lever. that should turn it on and off.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
There should be a secondary hood mounted light if it was optioned with that. It may not have been.
boarder421
