Under hood heat
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I am considering some hood vents.
Nothing Flashy.
Just one simple vent on each side of the body line.
Anyone do this?
Any ideas on which vent.
Kinda leaning toward XJ vents(these in particular).
I am not overheating, I actually run really cool. But you would not know that popping the hood.
Shorty81
Baby Boomer
North West ohio
Darren
No not I. I like the Flag vents, but I would not vent a hood. That would let water in.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Agreed. Need to be louvered.
Really liked the look of those out of all my searching.
dvdswan
Port Orchard, WA
Dave
I installed some louvres from a 85 Pontiac GTA to vent the engine heat.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
How did it all work water wise?
I like that setup. But I really like those flags.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Hardbody?
For anyone interested in doing this those gta vents are probably not real easy to find. Chevy Lumina had a similar hood vent and they made a ton of those.
CoggedBelt75
Oklahoma
Joe
I ran the ultimate vent for 2 years...no hood. Took that long to decide to cut the hood for the bug catcher. Blower and injection was new so hated to cover everything up. Drove her daily, even in the rain. Water was never an issue. If anything, it will let you know if you have bad plug wires:). Just more cleaning to do than normal.
Just recently had to do it again while hood was repainted. Still, the hood isn’t sealed so water still gets in. But it does let some of the heat from the blower escape.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
The cut hood for the win over the giant scoop/ upside down sled.:D
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
So I see no issues with the flag vents as is.
dvdswan
Port Orchard, WA
Dave
Hardbody?
Yes, Hardbody.
AFWIW, the GTA hood was bent, so I didn't feel bad about cutting it up. $20 at the j/y couldn't pass it up.
Truck still isn't finished. There is some intrusion when I gave it a bath, nothing terrible though. I think the setup will work well when I'm wheeling to allow heat to escape. Space is very tight in the engine compartment and I'm having difficulties trying to decide where to put my trans-cooler. I've thought of installing it under the pass. side vent but I think the heat will affect the cooling effect of the cooler. Custom builds, easy at times, head scratching at other times. SMH
4WDKC
Southern Florida
Kacy
If you put the closer to the outside edge you wouldnt have to worry about water getting on the plug wires or exhaust and causing steam while driving in the rain.
TravisB
Travis
You can shim up the rear of the hood and let heat out. You mentioned XJs that is what I did with mine. It was fine until you were in the woods so I just made some .5-.75 inch shims and used a longer hood bolt. Makes the whole thing sort of like a scoop. Looks a bit strange but lets heat out without cutting any holes if you want to try before you buy sort of thing. Or buy one from someone whose folded theirs from not oiling the hinge and let it vent out each side. lol
This is what I am talking about:
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
That was the rage in the 70's for NYC taxicabs. Not so much for the common folk.'
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
I mentioned this very thing in another thread, being that's what all the Hondas around here do.
I am pretty set on some vents, I don't mind cutting a couple holes in the hood.
Thank you for the suggestion.
Oliver90_08
