Turn signals
77scottsdale1
Scipio Indiana
michael
k20
Where do I find a turn signal fuse? Or if there is not a fuse, what would I look for, for them to not be working?
There should be a round, two pronged turn signal relay plugged into the fuse box. Do your hazards work?
77scottsdale1
Scipio Indiana
michael
k20
Yes my hazards work. I did find a few connectors plugged into the fuse box, one was black and the other was white
77scottsdale1
Scipio Indiana
michael
k20
There were also two round pieces of what looked like aluminum in the corners of the fuse box
That's them. The relays usually look like stainless or aluminum cylinders with a flat head.
1973c10
Don
Alright, so you think those went bad?
Considering the hazards work, I'd say the turn signal one went out. It's the cheapest, easiest potential fix. It's the lower flasher relay, by the way. The upper one is fine.
twzorek
