Turn signal question
rwljpl
Alabama [AL]
Rich
Here is the situation:
Left turn signal works perfectly. Hit the right turn signal and the light on the dash and the signals front and back stay lit solid. If I turn on the hazards everything flashes as it should.
What’s wrong and what do I need to fix the turn signal that won’t flash?
TIA
Shorty81
Baby Boomer
North West ohio
Darren
You have a bad ground. Check for corrosion .
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Usually if the green dash light stays solid its a burnt bulb
rwljpl
Alabama [AL]
Rich
That’s the thing - my grounds look good and the bulbs all work. Any more suggestions?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Turn signal relay, maybe? But I would bet it's a bulb problem.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Did they work correctly previous?? Maybe one bulb is in the socket in the wrong orientation also....
Snoots
Roger
Jimmy Sierra
350 w/203
Turn on your 4-ways and do a walk around. I'm guessing a bad bulb.
Scotty D
Convoy, Ohio
Scott
C10 Bonanza Big10
Hazard lights and turn signals are on 2 different circuits, so if the lights work correctly when the 4 ways are on, you know your bulbs are good. it may be in the turn signal switch in the column - but it does seem like a ground issue in the dash or cab to ground somewhere
rwljpl
Alabama [AL]
Rich
Left turn signal stopped flashing last night. Figured it had to be the relay after that - and it was. Stopped by the auto parts store for a new relay today and that did the trick. Everything is good now. Thanks!
