Truck won’t turn. What’s that sound?
73_Stepside
Los Angeles
Steven
Hopefully this is in the right thread. Could you please help me identify what this sound is? New starter installed. New battery. This is after spray starter fluid into the carburetor. Thank you.
Chevy 88
Canada
f7t6
GMC
Sounds like the starter is spinning up / down with the engine.
As for starting, I would fill the float bowls through the vents, and then give it a full 2 second shot of starting fluid.
73_Stepside
Los Angeles
Steven
Thanks for replying. For the starter, would that mean that i installed it wrong? Or something that its just doing cause its not turning on?
Chevy 88
Canada
f7t6
GMC
The starter might just be the way that one sounds. Or it could be getting stuck on the flywheel, or maybe something else. But I would start with the engine, because if the engine wont run for more than 1 second, then the starter doesn't matter. Did you try that fuel thing, filling the float bowls?
Strick
Dunn, NC
Harold
C20 Crew
Check the ignition starter switch on the steering column as well.
HS
73_Stepside
Los Angeles
Steven
Not yet. Need more fuel. Waiting for my wife to get back. I was thinking maybe I should have shimmed the starter, but I didn’t cause there weren’t any on when I removed the old one. I’ll try the fuel thing later on
Chevy 88
Canada
f7t6
GMC
You may already know this, but you can mess a starter up, damage the flywheel, or even break the starter mounting bolt holes right off the engine if you shim it wrong. There is a very specific procedure when shimming, not just guesswork.
As long as the starter turns the motor over, that's good enough for now. Same reason you don't fix the muffler until the engine actually runs.
Once it starts and runs, then you can evaluate the starter to determine if it needs shimming or anything else.
As for the engine- I think you are not getting fuel, and based on the video it sounds like you used very little starting fluid.
73_Stepside
Los Angeles
Steven
I’m going to try again Tuesday. I will let you know how it goes. I really appreciate your advice. Thank you.
^This. I hear no issue from that video. The high pitched whine is just the bendix in the starter retracting and slowing back down till it starts. You normally don't hear that if the engine lights off and runs, you just hear it cuz the engine died
The Right side of Washington
It is however really cool to see some new participants here on the forum recently that are getting into old cars/trucks/squares, that have never heard an old car almost start or never known what/how a mechanical fuel pump works.
Keepin the old stuff and old knowledge alive….
waterpirate
delaware
v10
5.7 tbi
Sorry I could not help myself.
73_Stepside
Los Angeles
Steven
I want to thank everyone for their input. I’m just getting back to this truck and trying to get it to turn. Here is the carburetor. Where are the bowl vents on this thing. I wanted to add fuel but don’t recognize the bowl vents. I thought they’d be sticking out.
Chevy 88
Canada
f7t6
GMC
Will the motor turn over?
Will it fire on starting fluid?
If not, I would not fill the float bowl with gas.
hauto85
