transfercase not turning the rear driveshaft?
bigben129
Ravenswood
ben
1/2 - 3/4 ton
350's
which transfer do i have
whats the difference between 203 and 208?
ours has a shift knob with the hi and lo lock on it.
anyway my question is .......
it wont turn the rear wheels when shiffted into 4 low or 4 low lock.
any ideas why.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
208 is aluminum case and has 2-Hi on it, 4 lo loc and 4 hi loc are only on the NP203. There's a countershaft for low range, something may be up with it. Fork or synchro hub problem. I got an exploded view of it around here somewhere...
bigben129
Ravenswood
ben
1/2 - 3/4 ton
350's
Ok must be 203 cause 2wd is not an option unless you unlock the hubs
Can i replace this with a 205? What do i need to look at? Thanks
crazy4offroad
K-10
350/SM465/NP205
You'll need an adapter/mount (goes between the trans & t-case) and shifter, and of course a 205 with the fine spline input shaft for coupling with a TH350. You may also need the front & rear driveshafts, depending on if you have it set up for slip-yoke or slip-joint driveshaft.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
WOOO!!!! Unlock the hubs? NP203 is a FULLTIME transfercase and lock out hubs are NOT used, instead they have drive flanges inside the hubs.
Now there is a Part time conversion kit that can be added to the 203 to make it a Part time transfercase. I am wondering if someone possably did the conversion to your transfercase and it has failed? Maybe C4 can enlighten us on just what the conversion is and if its a possability. I have been told that the Part time conversion kit is NOT a very good kit, I was told that the transfer case will not last as long. Why I dont remember, again maybe C4 knows something about it?
crazy4offroad
K-10
350/SM465/NP205
Part time kit in a 203 reduces longevity because of insufficient oiling in the case. From what I've read you have to put it in 4WD occasionally and drive it around to make sure everything is lubed. As far as what's involved internally I havent a clue, never done one but I'm sure there's plenty of info on the net about it. The simple test would be to unlock the hubs and try every range going slow while someone walks alongside the truck watching the front driveshaft. If it quits spinning in one of the ranges then it has the part time kit, and may be more desirable to someone out there. IMO the best thing a 203 has to offer is as a range box in a doubler setup.
sallyjeank10
