Torque spec for transmission mounts?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Can anyone tell me the what the torque spec is for the rubber transmission mounts? Can't seem to find it in my manual.
Tight as hell, that's all. I've never known this to be an issue. I just have used a 1/2 drive ratchet and got them tight as I could and never had a problem. Maybe someone else has the spec, but I've just never had an issue with as tight as I could with a 1/2in drive ratchet. I don't think I'd go using a breaker bar and get it so tight I stripped out the aluminum although it's not all the delicate with those bigger bolts. It's the 1/4 and 5/16in threads you need to be careful about stripping out.
74 Shortbed
To the case or the crossmember?, either one just snug them up good they have lock washers they ain't going nowhere.
Yep, I've never hurt either and never had one come loose. They're 5/8 thread, so they grab alot of meat.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
No lock washers to be found on mine. A bit of thread locker residue, but that's it.
74 Shortbed
Well, they come from the factory with lock washers so that means it's been apart before, but Blue Loc-Tite works just as good..
87Chevy520AZ
