DoubleDingo
- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Okay all you guru's in GM-Square-Body-Land, my new 1981 truck with 69,000 miles on it runs great, however, it shifts quickly and softly which is just not cool. And it doesn't downshift when going up hills or when taking corners at slower speeds, so the fuel economy is being affected because the engine is not at good torque points.
I checked the vacuum line and it was all mushy at the trans. So I put a new piece on there, but not until I drove it without the vacuum hooked up. It wouldn't shift which is what I expected, and I didn't want to rev it up too high through the neighborhood. After hooking up the vacuum line I decided to start manually shifting at the desired speeds and downshifting the same way. Forgot how hard the TH400 shifts at higher rpm's.
Anyhow, Saturday I was leaving a bbq, started up the truck and saw white smoke coming out of the tailpipe. It didn't keep smoking, but I suspect there is ATF being sucked up through the vacuum line. I checked the fluid level and all is well there, except it needs to be changed. Sunday when I started it up it did the same thing.
I was planning to switch the modulator valve anyways, and want the adjustable kind. Which one do you guys recommend? And does ATF come pouring out when the old modulator valve is removed? Also, do you know of any other issues that may cause white smoke to come out the tailpipe? It's not blue smoke and doesn't smell like motor oil.
Thanks.
Shane
Thanks.
Shane
