TH350 Bellhousing
Should I bother fixing it or get a new transmission?
  • Rebuild it
    Votes: 1 33.3%
  • Buy a new one
    Votes: 2 66.7%
  • Total voters
Welch78
Burlington. WV
Caleb
K15 and C15
I pulled the transmission out of my 78 Sierra. I'm pretty sure it isn't the original, but I started tearing it apart and noticed that hole and I wasnt sure if it was supposed to be there or not and I was hoping someone could help me with this problem of whether it's supposed to be there or not. Thanks in advance.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Go to a trans shop and give them your case, often they’ll have scrap cases that they’ll cut your missing piece from and they may be able to weld it in and repair it for you
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I assume that’s looking UP into the valve body area? What’s the other side look like? I don’t have a TH350 case here to look at
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Definitely not supposed to be a hole there lol
CSFJ
You mean the factory didn't include a jagged irregular shaped inspection hole in that location?
nvrenuf
Mobile, Al.
If the hole were in the bellhousing you could easily fix it with an Ultra Bell, that's not in the bellhousing it's further back.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Every TH350 ever made has that hole.
Knightewulf
