tbi 5.7 collapsed lifters
allweld488
preston,iowa
chuck
k20
355 tbi
new to the post but maybe someone can help me , I recently rebuilt a 91 5.7 tbi engine, we already did the breakin and everything has ran great the last few weeks, but I noticed my rockers making noise so I adjusted them,now here is the problem its been a couple days since I last adjusted them and now i noticed I get zero oil to rockers, now I think I may have adusted them to far and collapsed the lifters, I loosened them up some and ran the engine to see if they would come back and started to get oil again but they are still not blasting oil like they should,WILL THEY COME BACK or do I need to replace lifters or is there any ideas to get them back up again.
350runner
tx
Ceasar
I'd replace them and use a different method for setting the valve lash. 2 if the rockers aren't moving I'd look at your cam :-(
allweld488
preston,iowa
chuck
k20
355 tbi
rockers move great and I marked pushrods and they spin great while running so I think cam is fine.
350runner
tx
Ceasar
Awesome! Still look at the cam to check for an irregular wear pattern.
Swims350
Logan WV
none
when you pull the lifters look at every bottom and compare it to the side of another to check for any concave or dish to them bottom. If they have dish then you need a cam and lifters.
allweld488
preston,iowa
chuck
k20
355 tbi
I plan on pulling it apart tonight and tomorrow morning so i will keep you posted as to what i find.
allweld488
preston,iowa
chuck
k20
355 tbi
well I got everything taken apart and the lifters and cam still look new, i guess next step is to reorder new lifters.
350runner
tx
Ceasar
Order from a well know manufacture and ask how they set their rocker preload. This way if it fails it's on them as the conversation will likely be recorded :)
blackghost
