Swap a th400 for sm465 worth it?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
i found an sm465 on CL for $200. Would it be worth the swap or just wait for a decent deal on an nv4500? I know the final ratio isn’t different, but figured the lower rotating mass would improve efficiency. Would it be much of a difference?
Customblue
Locust Grove, Va
Brandon
As long as you don't mind slow shifting, I'd go for the sm465. I really like the creeper gear, very useful for a truck that will be worked. Plus you would feel more hp and torque compared to the robbing th400. I believe the granny isn't the same length as the auto so you might have to find the correct drive shaft or make it up in the t case adaptor.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
You wont find a "decent" deal on an nv4500, they are what they are. If it's cheap, it's likely broken, or missing parts. It might help you be a little bit ahead of the game by having the clutch pedal assembly but that's about it. If I were you I would just start accumulating parts for the nv4500 swap if your TH400 is working fine. That stuff's too heavy to be handling more than once.
What output and adapter does that 465 use?
The 400/208 combo is the same length as the 465/208 combo. And so is the 700/208 combo actually.
Customblue
Locust Grove, Va
Brandon
I didn't know that, so if someone wanted to swap to a 350 from a 700r4, just get the appropriate adaptor and run existing driveshafts?
wilson79
