Suburban Tailgate - Glass won't go higher than 2/3 full stroke
Mojito5000
Ryan
V2500
My first big project on our Suburban is to get the tailgate to work, in the 6 months we've had this truck we've never been able to use it as it needs to be used.
So, I purchased all the parts to convert from the powered tailgate and converted it to a manual crank from LMC. I got the everything swapped over and can articulate the glass up and down with ease, until I get about 2/3 the way up. Once I get there it feels like there's some sort of mechanical bind, the glass just stops moving. I was wondering if there was a safety switch on the latches? The tailgate closes and both latches are fully engaged. I felt around inside the tailgate and nothing felt like it would bind, but I also had the glass in so I couldn't feel behind it.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
There is a safety switch on the electric window tailgate, but IIRC (been many years since Dad and I rebuilt one) it only keeps the window from functioning IF the tailgate is down/open. We had to bypass this switch to run diagnostics on power window 'gates that we had issues with. We never had a Burb with manual window in the 'gate so I don't know how they compare.
Mojito5000
Ryan
V2500
I unplugged the safety switch, but left the "guts" in. I'll pull the glass tomorrow and see if I can get a better look at it.
Mojito5000
Ryan
V2500
Following back around on this, if anyone has a similar issue, check the bend on the regulator arms. I don't know if shipping damaged them, but they were pushing the window into the latch mechanism, and the latch was catching on the channel that holds the bottom of the window.
Nborden88
