Steering Column
bigge31566
GA
Ervin
I have a 1983 c10 that i just purchased and the turn signal handle is not on vehicle, but i can move switch with screwdrver, how hard is it to replace, it had cruise control but not anymore, also someone put a grant steering wheel on it
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
it's about a hour job. if it has tilt it's alot harder than a non tilt. Might be able to pull steering wheel and lock plate off and get luck and it just need a lever and screw. I've had a few the screw has came loose and lost lever over the years. Lever and screw the same 70's gm car truck. If it was a 84 up with dimmer and wiper switch in turn signal all it takes is pushin in and turning lever and they realease to remove them. There also same gm car and truck 84 up to 91 or so
81k1500
