Steering column issues . Help please :)
spud
mount prospect ,il
peter
87 r10
r10 , custom deluxe
5.3 ls
Hey guys new here ! I have a favour if anybody can help me out . I’ve searched everywhere .
I have a 84 floor shifted 4 speed column , non tilt , that I’m trying to fix up . I’m stuck at the part where I cannot remove the housing cover to get to the wiper switch . Like auto or , 3 on the tree columns the housing just slides out after you remove the bolts and ignition cylinder and etc . And this one after removing everything it’s not going anywhere . Im wondering if anybody can help me out . Thank you
I’m stumped , help haha !!!
awar
K35
If I remember correctly, you have to remove the lock cylinder next. Then it will slide off.
spud
mount prospect ,il
peter
87 r10
r10 , custom deluxe
5.3 ls
Hey thanks for the response , even with the lock cylinder out it’s does not wanna budge . I just have it in there so the gear don’t move . So on auto and 3 speed ones it just slides out enough to be able to undo the nut that holds the wiper switch . Also on autos ,non tilt there is a cover that you remove to acces the switch . On my column the cover is molded to the bowl of the steering column.
awar
K35
I think the gear needs to slide out of the shroud, the switch keeps it from sliding. The gear is trying to turn the switch.
spud
mount prospect ,il
peter
87 r10
r10 , custom deluxe
5.3 ls
That is a possibilty actually . Didn’t think about that . Will check it out . Thank you
Shifted
