Stake bed + face change... possible?
botas
Los Angeles
Allan
c30
Hello everyone, recently I've been packing what life had hit me with being a fresh legal adult. But I'll always make up something for the junk I got home. (75 dart, blown 02 S10 i got a donor for, etc etc)
I have a 84ish sierra 3500 dually single single cab sitting around and ive been in the means of trying to change it up a bit
first of all, My Pops is pushing me to change the face on the ugly MF because the grill is sun beat and he likes the older look (80-82) considering the truck has the face of the 82 diesel optioned face (instead of 4 headlights its 2 singular with a Buck ton of plastic trim filling the spaces) either a suburban change or classy 80 look instead of the old head look.
Another task: It was my Uncles welding truck, He sold it to us not too long ago and he'd like to use the welding stake bed in exchange for a long bed. I havent taken at look at it yet but any pointers taking those large and instrial sized beds? Its all around makes it look like a unit of a truck all 12' of it.
thoughts? Let me know if im doing anything wrong.......... ill provide pics
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Looking from underneath, are there holes in the top frame rail for bed bolts? If the answer is no, you have a c&c, and they were not designed for a normal bed.
Look at the gap from inner tire to the frame. Huge gap, normal truck. Tiny gap, c&c. Example shown is a gmt400 c&c, but the same principle applies. There were a few special order normal bed trucks with a c&c dually axle and metal “flare”, but the odds of actually finding one outside of the Saudi oilfields or rotting in a government yard are astronomically low.
Go full odd duck up front… 81/82 bumper and turn signals, stacked quad lights, 83 grille center. Retrofitting to the 1980 (only) front end is more work than you’d expect…
The Right side of Washington
Most all 80s front clip parts are interchangeable. As for your other question, not sure anyone understands what you’re asking, but if it’s “Can you replace a 12” long stake bed with an 8’ long pickup bed?”, the answer is NO, not without a lot of cutting welding and modification.
If you have a 12’ bed now, it’s a long wheel base C&C. Prohibitive to modify into a pickup truck IMO unless you’re good enough to be cutting and welding frames.
Sierra_87
