Some T case identification help please.
A better pic of the Tcase to bellhousing strut rod.
Then here's one of the short strut rods from the aluminum K Case Torque Converter/Flexplate cover to the engine mount. There's 2 of these, one to each engine mount.
@HotRodPC , should a manual have them as well?
from what i gather the sm465 and the adapter is robust and short/strong compared to aluminum a wide th350 casing so it doesnt need it. apparently that torque-twisty movement between two cases(th350 maybe is cast iron, but its still brittle compared to sm465??) breaks the bellhousing thingy
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Interesting. Just working on figuring out why the T case on my 84 is cracked??
lets see it in one large shot, perhaps you have a slapping condition with objects such as the ground or a mount broken or perhaps you have a really good clutch and like to dump the clutch as the kids say and you have 400hp at the wheels
I'm not sure if the SM465 got the short ones from the flexplate cover but I've seen the long one used for SM465.
HOTFOOT
northwest ct
michael
gmc k3500 srw
my 80 gmc k3500 400/400/205 has all three rods
thats good to know, that there are 3. wonder about manual tho
@HotRodPC where does it run to and from and do you know if its the same as th ones? length wise
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Are 465 and th drive shafts the same length? If so, then length wise the strut should be the same, no?
i thought i read something about certain year/certain t case having the same lenght and i think it was later np208 and sm465 to earlier np205/th350, but maybe only certain years.
johnalen76
