SM465 cab swap
tally99
Northern IL
Robert
k2500
Hello, I Have a 78 k20 4speed 4x4 with a rusted (completely dead ) cab
I took the truck apart a year or so ago and recently bought a cab off of a
77 two wheel drive auto, I have everything from the old cab, but there is one problem
The new cab's "trans tunnel" is shaped totally different, so i cant just cut the
hole and use the access cover from the old one, I have 3" of body lift, can I just cut the two shifter holes and count on the body lift to make up the clearance?
Any advise is greatly appreciated
-Robert
Boone83K10
Boone, NC
Benjamin
the tunnel shapes are completely different for 2wd autos. Manual trans 2wd trucks and all 4x4 trucks share the same trans tunnel. IMO it won't work even with the body lift, but you can certainly try.
tally99
Northern IL
Robert
k2500
that is what i was afraid of,
I guess ill set it on to make sure and make a custom
plate if needed
thanks
Driver4r
Nebraska
Trevor
k10,c20
Why wont it work?
You take the bolt down hump out of the 4wd cab, and cut out the 2wd hump, but leave enough of a lip to be able to bolt down the 4wd hump.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
with 3" of body lift I dont see why you would have to do any more than cut shifter holes. worse comes to worse you can set it up there and mock it up and if dont clear your out nothing since you will have to cut hump out anyway.
Stroked
Beloit, Kansas
Jared
That's what I was thinking. Can't hurt to try
Sent from my iPhone 4s using Tapatalk
tally99
Northern IL
Robert
k2500
thanks for the replys everyone,
ill plan to do a test fit the next weekend i have off
ill keep updated on it just in case it ever helps anyone else
....also thinking that making poly bushings isnt that hard
can always lift a bit more
1987_chevy
Vermont
Dylan
The cab in my truck came from a 2wd auto. It just has the tunnel out of a 4wd standard. It's just screwed down with self tapping screws, looks and works fine. And I also have a 3 inch body lift btw.
tally99
Northern IL
Robert
k2500
cool thanks,
like i said, i didn't cut a hole yet
i just set the cover over the tunnel and got concerned
that the floors were too differently shaped
glad to have verification that it works
-Robert
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
I've got a removable hump, and the flange for it I just cut out of the floor of my 80 cab if you need one.
tally99
Northern IL
Robert
k2500
Awesome, I'm not sure if ill need it,
but ill definitely send you a message if I do
FenderBanger
