Sm 465
CSFJ
I'm not sure what those are. They have the wrong shift tower to be a 465, and I'm unfamiliar with what is going on with the gear on the output shaft. I may be very wrong about this, but I almost want to say those are ford transmissions from the design of the shift tower.
Boltrunner
Odin mn
Shane
V20
Ok ill stay away from them then.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That is very remenesant of a Jeep Dana 20 input gear.
CSFJ
I did some image searching, of the nv4500, m465, and ford t18 transmissions, and none of them match. The gears on the output might mean they're from some other equipment.
CSFJ
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
This is what made me think Jeep...its a TH400 to D20 adapter.
CSFJ
You could be on to something there. I just can't remember the model numbers of all the old jeep transmissions to check.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
T18?
CSFJ
The trans in the ad aren't even the same unit as each other, ffs.
Edited for clarity.
CSFJ
Alreadty checked the t18, knew they used to run them in fords as comparable to the 465/420 units. Looked up the sm420 too, still no match.
CSFJ
I google searched the t18, and the images kept showing 3 shift rails under the tower. Both of the ones in the ad only have 2. Otherwise, it was the closest
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Well if that's what it is I have 2 D20 cases sitting here.lol I did have one in my truck but the front shaft angle was way to severe.
CSFJ
I Googled ford t18s, apparently they use a different shift tower assembly. The jeep t18 is a dead match.
damon18
