iamtherealJayy
- Nov 26, 2021
- Tennessee
- Jacob
- 1987, 1978, 1976
- V20, K10, K10
No, as far as I can tell the neutral safety has been cut and wired together because I do not have to press the clutch to start the truck. Which is a good thing in my opinion lol I’ve had to start the truck in gear a few times because the slave/master went out all of a sudden. I have a cheapo vacuum bleeder but I haven’t tried it with the clutch because it’s always been such a pain to bleed and I don’t want to introduce air into the system. The first time I changed the slave I had to end up unbolting it then bolt it back on because it just wouldn’t build enough pressure to extend the slave arm. It was pushing clean solid fluid but had no movement in the slave. I undid the two nuts and it popped right out topped fluid off and bolted it back on and it worked fine for a while then the one time I pull a trailer I go to put the truck in reverse and my master cylinder goes out and can’t go into any gears and the shaft to pedal is wet.
Edit: I thought about doing the bottle of brake fluid with a hose ran into it method of bleeding the brakes but I don’t know how it would work for the clutch.
