Skyjacker 7255 dual steering stabilizer kit instructions
EthanPhillipsK30
Illinois
Ethan
D30
6.2 Diesel
I had just recently purchased a Skyjacker 7255 dual steering stabilizer kit for my 1984 K30. It came with the wrong instructions. The drivers side dampener bolted up perfect like it should but I have no idea how the passenger side bolts up since the kit didn't come with the correct instructions. Has anyone ever had experience with this specific kit and could offer help?
Tonimus
Phoenix
Tony
C10 Suburban
Tonimus
Phoenix
Tony
C10 Suburban
When you click the first search result, it takes you to the skyjacker page. I believe are two instruction sheets because the kit consists of two different installations. One set is for the driver's side, the other set is for the passenger side.
EthanPhillipsK30
Illinois
Ethan
D30
6.2 Diesel
The instructions dont have the square body track bar. The image depicts what appears to be a dodge steering setup
Tonimus
Phoenix
Tony
C10 Suburban
Track bar? It all bolts to the tie rod. The one side is a direct replacement and the other bolts to the axle tube with one bracket and the tie rod with the other.
EthanPhillipsK30
Illinois
Ethan
D30
6.2 Diesel
Tha
Thats what I meant. The drivers sided bolted up just fine, im just insure how the passenger side bolts up.
Tonimus
Phoenix
Tony
C10 Suburban
See "Photo 1" in the 7110 instructions. Axle tube and tie rod. Just mirror what you see so it's on the passenger side.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
It wont help a thing if your tie rods are shot and ball joints are worn.
it may help a lil bit if you have cross over steering. IMHO.
Get a steering box frame support kit,
all that stress will eventually crack your frame where the steering box bolts to.
clee
