seat belt extender
SirRobyn0
Rob
Ok, I must not be the only fat ass that likes to wear his seat belt. Ok, so I actually do fit the seat belt, but I'm big enough that it uncomfortable. And I can't seem to find a seat belt extender, that will fit the buckles. I'm not looking for the kind you bolt to the floor I'm looking for the kind that clicks in between the seat belt and the buckle. So if someone recently bought one and happens to have a part number, or at least remembers where it came from, pretty much anything will help. Thanks.
Could you change where it mounts? You might try a dealer service department, they made a lot of money on that kind of part and GM used that buckle style for many years , my 1990 owners manual mentions that if you need a seat belt extender to try a dealer parts department.. worth a shot. I know depending on item ford will go back to 1980 on stuff like that, but no earlier than 1980.
SirRobyn0
Rob
No luck at that website, if you actually try to order any of the varieties listed they show as not available.
I did not think to try the dealer, but I will in the morning.
Did you specifically select a K series under the model selection? If you put in 84 it will give you all the modern names but also at the bottom it has a K2500 and K1500, maybe would work. I cant imagine the 3/4 ton had different seatbelts to the half.. haha
SirRobyn0
Rob
aaron06
