custodian
- Apr 15, 2016
- Catawba
- William
- 1973, 1985, 1986
- C10, C30
- 5.3 LS, 350, 454
I'm cleaning out my building of all my older SBC stuff. I have 2 quadrajets, one I know is good to go the other I'm not sure, a 1964 283 bare block with main caps that's never been bored, a 307 block with crank, pistons and rods (disassembled), a rebuilt points distributor (almost new), Used 350 2 piece rear seal crank (most likely needs turned}, 307 2 barrel intake, 350 non egr quadrajet intake, used oil pans, 283 valve covers, 350 GM crate engine vale covers pulled to install chrome ones (NEW), a new set of center bolt 350 valve covers, a set of Oldsmobile MOROSO gold anodized that have been painted Olds blue (NEW never used), and whatever else I find. I'll post some pics later. Make me an offer and come and get it.
UPDATE: 2 flywheels (one is for an 11" clutch, the other for a 10.5 clutch, cast iron bell housing from a 67 C10, 5 bolt aluminum bell housing from a 73 C10, used Comp Cam 268 duration, 454 lift cam, box of used valve springs and valves. I also have a set of 327/250 heads with Wolverine valve springs, TRW valves and valve locks with about 30K miles on them, bare 350 heads, 283 heads (will need reworked), also have 350 heads with valves and springs.
Also have some 87-93 Mazda B2200 truck parts.
