SBC 427 or 434 questions
75Monza
Colville, Washington
K30, K20, K20
Had some motor questions not related to square body, and since this is for a small car, not sure if anyone has built one of these here. So I started seriously thinking of what motor to build for my 75 Monza Towne Coupe and immediately ran into a question.
I was thinking of doing a 406 0.030 bored 509 casting, but getting harder to find a good block, so started looking at aftermarket blocks. Really interested in either a dart 427 or 434 short block, would match up great to a set of Iron eagle 230cc 2.08's I've had stashed away with a good roller Comp cam. Want to keep it around a 10.5 cr so I can run it on pump gas, researched building one of these and think that it shouldn't be too much to get 500hp to the wheels, this is around a 2,700lb car. My biggest challenge will be keeping suspension together, keeping to the stock 3 link design with torque arm set up, but modified parts since it works real well.
Question I'm wondering with any of these combo's is would I be able to set up a cooling system that would keep it in the green on the street? While I'm drawn to the 434, wondering if the 427 would run slightly cooler. This would be mostly a street car because I don't plan on doing a cage of any sort, just suspension mods. Want to keep the car as stock looking as I can from the outside and not cut it up too much since there are only around mid 50's of these registered left.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I'd think that the 6 cubic inch difference would make much of a difference in operating temp. With a good radiator, fans, and coolant in a light car I think it would be fine.
Sent from my Moto Z (2) using Tapatalk
Hard
