RETRO-Mod: Jeep intermediate steering shaft
4WDKC
Southern Florida
Kacy
It is alot better, I think the rest is in the gearbox.
smurfasaur
Central WA
Austin
Anybody run into an issue with the Jeep shaft splined end not fitting onto the GM steering box? Happened to me, bought an XJ shaft, shortened it and it won’t go on. Then I broke out the caliper and the Jeep shaft splines opening is at least 0.1” smaller than the splined shaft on my K20 steering box. Didn’t bother to test it when I took the old shaft off because it seemed like everyone was doing this mod without any issues.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Was it from an XJ?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, something’s fishy here. More specifically, was it the correct year range Cherokee?
smurfasaur
Central WA
Austin
Yep it was an XJ. Just went back to double check but it was from a 1989 Cherokee. Wikipedia tells me XJ’s are cherokees from 1983-2001. I didn’t think it needed to be from a specific year XJ?
beest
indiana
matt
Iirc mine was from a mid 90s cherokee with a 4.0. Fit fine. Didja try to pry the pinch open just a bit?
Sent from my SM-G920P using Tapatalk
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
That year is fine. It should work. I would carefully attempt to perform the aforementioned suggestion.
smurfasaur
Central WA
Austin
It’s a virgin it needs exercised a bit.
Heh heh.
I did try to heat it up and pry it apart a lil to get some more space but it didn’t seem to move much at all. I’ll put my big boy panties on and give it another go
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Could you post some pictures of the shaft? Just of the shaft itself and the ends?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Wow, that sounds gay. It didn’t read like that in my head.
beest
indiana
matt
Just the tip....LOL
rickybobby69
