RETRO-Mod: Jeep intermediate steering shaft
jetman
Minnie, AK
Don
A close up of how you hooked that up would be great. I'm wondering how you got around the U joint and kept from tearing the U joints apart.
Hooked small chain thru upper u joint, strap thru lower u joint.
Granted, these u joints are fragile, but I picked up two just in case one got screwed up. Small tap w/ 16 oz hammer pulled em apart. I prolly pulled ~ 300# with the strap, did not ratchet down on it too much or bounce the bed too much, came apart surprisingly easy.
If more force is needed it is a simple matter to wrap chain & strap around shaft before u joints. If all else failed, heat could be applied while hanging in this position.
I'll have to give it a try next time I do one.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
B Body Jeep Mod
Hey, guys. Did the XJ Intermediate Steering Shaft mod on the Caprice yesterday. Feels like a modern car at the steering wheel instead of a sloppy old junker. All I did was compress it by heating it with a cheapo propane torch and just slip it on, tap it onto the column while it was still good and warm, and bolt it down. Thanks @Mr Clean
bluex
Spartanburg SC
C15
I have a ujoint on order for the earlier trucks that does splined to d shaft on its way.
Did this work out for you? I have the splined column in my 78 an was considering doing this to get the shaft to work in it.
Wondering how the upper joint comes off the shaft mainly
The88
Mhmm
South Louisiana
ThatGuy
Anyone done the mod with a 3" body lift? I am looking to do it with possibly a YJ steering shaft from what I read in this 13 page conversation piece. I will probably look on the ole ebay for one and if the ends match up for me I will tackle it and be the guy that goes for the gusto. That's if no one else chimes in to say otherwise that the XJ shaft fits on a body lifted 88.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If you want to measure the length of your rag joint shaft, I'll measure one of my jeep shafts and see if it's the same or bigger.
The88
Mhmm
South Louisiana
ThatGuy
I can do that. But the only thing I have to do is get off this boat. I will let you know. If all else I found one for 30 bucks from a YJ. If I can play jew for a few bucks I may order it up to be at the house when I get there.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I gotcha, man. I actually think the XJ shaft is 21 inches, but I can double check if you want. I'm not sure if the YJ fits. It definitely looks longer, but I don't know if the spline on the Saginaw box is the same or if uses the same D shaped end on the column side. Is there a forum or something that says it does work?
The88
Mhmm
South Louisiana
ThatGuy
Also how much shaft should you have at a min/max in the slip joint? Just from lookin at the YJ shaft that bastard has plenty of material to play with.
The88
Mhmm
South Louisiana
ThatGuy
Yeah roger that. Guess I will be a google jockey and try to find the info on the size of each shaft.
The88
Mhmm
South Louisiana
ThatGuy
OK from reading around it looks like with a 1" body lift the xj shaft will work by tapping it in a couple inches. So I am thinking that with a 3" body in theory the XJ shaft should still fit as just about the stock length without trimming shaft. Not to mention if you can body lift an XJ by 3 and the shaft still work to swap said steering shaft to a K5 with a 3" body we should have more shaft penetration than the XJ does. So that means that guys running squares go deeper! :party36:
beest
indiana
matt
Mine has a 3" body lift. Worked perfectly.
Sent from my SM-G920P using Tapatalk
The88
Mhmm
South Louisiana
ThatGuy
Awesoem. Thanks. Did you cut any of the shaft or leave it stock length?
beest
indiana
matt
I didnt cut any off of it. Just heat to be able to compress, then heat to be able to pull it on. I used a mapp gas torch even. Took awhile, but worked before i got a real torch.
beest
indiana
matt
Made a huge diffrence in the steering on my rig. The rag joint isnt designed for misalignment and wears quickly when misaligned.
JOD26
