Daveo91Burb
- Jul 6, 2014
- Vancouver, WA
- Dave
- V2500 Silverado Suburban
- Vortec 383, modified TBI/4L80e
How do you reset or re-center this guy? It is tripped to one side and my brake light is on. Pretty sure I know why: PO or PO before him broke the bleeder screw in the right caliper, drilled it out, re-tapped with bigger threads and then screwed in a weird sleeve that the bleeder screw goes into. I'm guessing the intention was that the sleeve would stay stationary and the bleeder screw would unscrew as normal, but the opposite happens and it fails to operate as a bleeder (fluid just comes out around the sleeve's threads). It's making bleeding difficult and my messing around with it has caused the sleeve to leak, so when I hit the brakes, there is no pressure at that caliper and it trips the sensor. But all that's a guess so tell me if I've got it wrong! Anyway, will be installing new calipers but want to check if there's a procedure to get that sensor to reset. Or will it be automatic, once all four brakes have pressure? Thanks!
