Replacing a 400 small block for a 454 long block
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Hey yall. So my 1976 1/2 serria grande 4x4 currently has a sb 400 with 350 transmission. Engines original, but getting tired, my dad has a 1983 30ft pace arrow, 454 with 50k miles on it. I want to swap, so I'm guessing i might need a flex plate conversion and possibly a bigger radiator or auxiliary cooling fans to keep it cool. Is there anything else I should consider for it. Yall have more experience on here.??? Thanks
your 400 radiator may already be a large one, whats it look like
fast 99
Spokane, Washington
Actually, that is a bolt in. Flex plate from 454 should fit in the PU. Unless the PU rad has been replaced with a smaller one it should be adequate. Just be sure it is clean and fan shroud is installed. If it has a fan clutch be sure it is good. I wouldn't spend money new parts yet. Aux fans shouldn't be necessary.
Shorty81
Baby Boomer
North West ohio
Darren
My 496 has a 3 core radiator, direct drive fan, full shroud and runs cool as a cucumber.
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Okay good, it's a big ass radiator and new as of 2 years back
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
It's my all around truck. I plow snow and haul firewood, I do plan on replacing the transmission eventually but good to know it will hold up. I love how these trucks were built, very interchange parts
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
I'll deliver pics, it's late right now and I live in grizzly country
if its the equivalent size of a 3 or 4 core OEM and you replaced it with aluminum it probably is enough. if it comes all the way flush to the top of the core support instead of using a 2 inch step down plate to hold it and if the shroud is one piece(Most likely..) then it should be good
hrre is my dads 75 gmc radiator and that plate I mentioned. the 4 cores. I believe the 454s maybe came with a wider radiator possibly or depending on RPOs but if its aluminum then it transfers heat more anyway, making up for size. Thats why I ffigure you may be good ;)
Big Ray
North Carolina
Ray
If it were me, I'd throw a retrofit roller cam and and a decent set of heads with 64 cc combustion chambers. I think you'll be surprised.
64cc heads will bump your compression ratio to 9.1.
Here's a chart I found when I bought my rig with a 400 in it. BBC parts are expensive.
Washington
Would be a great swap for more torque (assuming it runs well) and bragging rights. Not so great on the wallet for an “all around” truck at the gas pumps.
But to be fair I’m sure the 400 with an Edelbroke doesn’t exactly sip fuel daintily either, lol.
More importantly, that Moho should have a TH475 trans in it. That’s definitely worth keeping, for obvious reasons, even if it needs rebuilt.
I love the Kettle Falls area only been up there once but it’s wonderful. If all it takes to bring in a Grizz or wolf is walking out to your truck at night, I’d do it every night….twice….with a .300WM and a spotlight! (And a shovel)
86sunnyguy
