Replaced Ignition switch....weird problem occurred after
TannerT
Oklahoma
Tanner
So i replaced my Ignition switch and when i would put it in reverse or drive it would die. However if i hold the column shifter towards me, it will stay running in D or R. Did i tweak the linkage somehow?
Dmack
Central OR
Dave
Sounds like the neutral safety switch needs to be adjusted. I believe it is mounted on the column near the ignition switch.
yevgenievich
Place
Name
Year
Model
Size
Neutral safety switch should be on the column by the firewall. But it working with shifter pulled up might be something inside the column not aligning correctly with the new ignition switch.
If you lower the column to where the ignition switch is visible, can try to observe what it's doing
zd76
